Can Midibox drive TLC5947 (24ch PWM, 12 Bit SPI)
Dear Forum, like the titel suggests. The TLC5947 can be bought in ready soldered modules and was suggested to me for dynamically driving solenoids, as an alternative to dac channels i proposed in my other thread.
Reason is the parts count, so before i build 24 ladders with analog shaping and drivers i thought i should maybe look into pwm once more.
So the question is if from within an mios32 application, i can use the SPI interface. If so i would try to code some form of "hello world" example with the pwm module first and then go from there.
Also is it fast enough? I need a pulse of less than 5ms to minimize the on time of the solenoids and give good response with pecussive instruments.
Has anyone done something similar?
Thanks!
