Transmit Data, call Functions, Log Information in TouchOsc with MIOS32_MIDI_SendDebugMessage()
-- Display MIOS32_MIDI_SendDebugMessage() messages and transmit data/trigger functions
-- this prints to the Touchosc Log window, as well as to a text element called "text"
local MIOS_MSG = root.children.text -- <- this text element must be in root, or simply change this adress
function log(msg)
print(msg)
text = msg.. "\n" .. text
--text = text .. "\n" .. msg
local count = 0
MIOS_msg_lines = {}
for line in text:gmatch("([^\n]*)\n?") do
if line == "" then break end
table.insert(MIOS_msg_lines, line)
count = count + 1
if count >= maxLines then break end
end
text = table.concat(MIOS_msg_lines, "\n")
MIOS_MSG.values.text = text
end
-- messages in the form of "Start .. ID .. list of numbers seperated by spaces .. End" can be used to transmit data to TouchOSC and call functions
local MIOS_SYSEX_COMMAND_FUNCTIONS =
-- numbers from mios are 0 based!
MyFunction = function(numbers)
print(#numbers)
end
function Do_MIOS_Sysex_Command(ID, numbers)
local fn = MIOS_SYSEX_COMMAND_FUNCTIONS[ID]
if fn then fn(numbers) end
end
-- sysex message handling
local sysex_buffer = {}
local last_sysex_time = 0
local sysex_timeout = 200 -- ms (adjust if needed)
function flush_sysex_buffer()
if #sysex_buffer > 0 then
local msg = table.concat(sysex_buffer)
sysex_buffer = {}
log("MIOS32 (timeout flush): " .. msg)
Log("[TIMEOUT] " .. msg)
end
end
function onReceiveMIDI(sysExMessage)
local now = os.clock() * 1000 -- ms resolution
-- if too much time passed since last byte -> flush old buffer
if now - last_sysex_time > sysex_timeout then
end
last_sysex_time = now
local headerLen = 8
for i = headerLen + 1, #sysExMessage do
local b = sysExMessage[i]
if b == 0xF7 then
-- end of SysEx, flush buffer as a complete message
sysex_buffer = {}
local ID = msg:match("^Start%s+(%a+).-%d+.-End$")
if ID then
local numbers = {}
for num in msg:gmatch("(%d+)") do
table.insert(numbers, tonumber(num))
end
else
log("MIOS32: " .. msg)
end
else
if b ~= 0 then
table.insert(sysex_buffer, string.char(b))
end
end
end
end
if you place this in your root script in TouchOSC, the text element will display the last messages from MIOS32.
I included a little parser that can be used to trigger functions and transmit data - like
"Start MyFunction 4 35 2334 4 End" that will call MyFunction({4,35,2334,4})
The way i am using this my functions are actually all in a list called MIOS_SYSEX_COMMAND_FUNCTIONS[ID]
so in this example :
MIOS_SYSEX_COMMAND_FUNCTIONS = {
MyFunction = function(numbers) print(numbers[1] .. numbers[2]) end,
