Guest djrazz Posted December 10, 2004 Posted December 10, 2004 ok i've done a weeks worth of reading and printed out every schematic and tried to figure this out but it seems i must ask when you use the motor faders in a contol suface i.e. axel design do these faders only contol functions?could the mf module be used as it is and run the faders in a mixing console ? it seems that it could run 12 mono tracks if this is possible could then those signals be used to control something like the mixer panel in propellerheads reason (www.propellerheads.se)if having a motorised mixer is cool on it's own espessialy a midi contolled mixer so all of your audio aoutput could be contolled
arumblack Posted December 11, 2004 Posted December 11, 2004 You can buy motorfaders with an audio track and control track, so you could use it as a mixer, but I think they are very expensive.
Rowan Posted December 11, 2004 Posted December 11, 2004 HiDepends on the console, on big expensive desks this is rather easy. On small and some mediums size desks it's almost impossible (Well nothing is impossible, but it would proble cost less to buy something the does the job)It all depends on how the desk was made and how much the desk is worth. If we are talking a 0.5 million dollar Neve or SSL I would say yes, good idea. If it's not it proably not worth it.I've got my eyes on a Neve orignal from EMI studios in london circa 1970 in a local studio that I'de LOVE to retro fit with Midi controlled motorised faders. The problem is convincing the owner of the studio that it's a good idea. Currently the desk has a old dodegy SMPTE based "Automation Computer", it's rubish. The thing is so old it only takes 5.25" floppy disks. This studio uses ProTools almost exclusively now so it would make perfect sence to have ProTools in control of the automation rather than some old bit of junk. RegardsRowan
arumblack Posted December 11, 2004 Posted December 11, 2004 I'm sorry, I seem to have misunderstood the question.... :-/
Guest djrazz Posted December 11, 2004 Posted December 11, 2004 there were two questions1 what functions do the sliders on the control suface do ?2. could i use a cheap (around 200) mixer i already have and replace the faders with motorised models andcontrol windows software or vise versa(contol mixer from windows) via midi this would be using faders as volume controls windows would only control the motorslike this example A :http://www.real-image.com/audio/digi/mmix.aspor the Peavey's StudioMixexample 2 http://www.sweetwater.com/store/detail/MCS3800/example chttp://www.mackie.com/pdf/hui_om.pdfhopefully this will explain what im trying to acomplish with the mbhpsort of a cross between a mb64e and a mb lc
Guest djrazz Posted December 11, 2004 Posted December 11, 2004 this is the mixer i would be sacrificing /offering to midi mios godshttp://www.behringer.com/MX1604A/index.cfm?lang=ENGsort of  intigrating the correct modules with some of the circuitry from the mixer to create the perfect mix of digital and audio controlsbesides who.5 million to buy a recoding studiothats why we build our own equipment
Steven_C Posted December 11, 2004 Posted December 11, 2004 I have thought of controlling an analog mixer with a MBLC derivative. Maybe you could put the analogue motorised faders on a separate panel, and route them as attenuators on your mixer's inserts, and leave the inbuilt faders on 0dB unity. (only ones I know of are penny and giles, for around $80 US each... better you find a way to build your own faders... alps motorised faders, plus some logarithmic alps faders strapped together in tandem... or buy an old console with an automation system at an auction or something... maybe not worth the hassle :'() anyway, drjazz, I'm not sure if you are aware that most of us just use the MBLC (like axels) to control the mixing functions digitally within applications like logic audio...
Guest djrazz Posted December 11, 2004 Posted December 11, 2004 anyway, drjazz, I'm not sure if you are aware that most of us  just use the MBLC (like axels) to control the mixing functions digitally within applications like logic audio...theres the answer im looking for as long as you can control your software faders this is really what i want anyways this will let you control as many tracks as you have on your system i.e. 32 or 64 ? more
Steven_C Posted December 12, 2004 Posted December 12, 2004 theres the answer im looking forGlad we cleared that up! this will let you control as many tracks as you have on your system i.e. 32 or 64 ? moreYeah, you use the bank left/right keys to change to the next 8 (or 16 if you have two MBLC's) faders. When you do this, the LCD becomes quite important to identify which channels you are controlling. (a disadvantage of those cheap behringer units)...Steve
Steven_C Posted December 12, 2004 Posted December 12, 2004 back to your original question, I really don't know what the midi implementation within reason is like. I doubt that it would be possible to use the MBLC the same way as it would work with Logic or Cubase, though I could be wrong....Steve
