test sid module with c64 psu
soudan
oh ok, i think i see what you mean now.  as far as i know, all you can do with only a sid module is test the voltages coming from certain pins (per the instructions at the bottom of the sid module page).  other than that, i don't think you can do much without a core module.
ok i figured so but just wanted to make sure...i had to reorder my core module because a couple of the contacts on the board must have melted off or something probably because my soldering iron was too hot..but i had the core working after a bit i just want to test the sid module..oh well have to wait the core
Sean
