Hi all:
I´m new to this forum and I was thinking on what Manufacturer ID to use in DIY projects which require SysEx dumps, like a knob controller
in order to set presets make assignements, and maybe upload firmware..
I mean which ID should be used if you´re a DIY'er or if you going to produce some MIDI gadget in low quantities and don't have the required $200 to spend in an annual fee at www.midi.org for a manufacturer ID
Thanks in advance
Nachus
Hi:
thanxs, so you say that should I implement some way to change the Mfr Id on the fly or give the chance to change this ID to the user in the event it conflicts with other manufacturer gear?
What do you think about a "SysEx Lock" dipswitch used to ignore all sysex incoming data? This can be useful for a knob controller since it needs programming only when you need to assign some knob to a controller or a channel, or to meka a preset. Then you can have a preset bank and switch between them on the fly.
Do you think it´s feasible for a knob controller?
Guest
Reply to this topic...
