gingercat Posted June 14, 2005 Posted June 14, 2005 Hi All,I've just been trying to put the finishing touches to my MIDI organ console, but in the process of doing so, I think I shorted something (PIC got very hot...) and since then my DIN modules won't work. After a lot of swearing and pulling of hair I think I've tracked down the problem:-DIN modules work correctly, I've tested them with my other core module-I can manually short the input terminals to the core module and it picks up the fake "inputs"-Clock out (RD3 on PIC) is running nicely-Ld pin (RD2 on PIC) isn't pulsing (I've tested this on a scope at work)So my question is (finally), have I fried my PIC beyond all repair or might a complete re-flash work? I can reprogram the core via MIDI so most of it is working (including the LCD).I think I saw a message on the LCD when I installed MIOS 1.8 (to try and fix the problem) which said "fixing...." but I didn't spot what it thought it was fixing.Thanks for any help you can give,Chris.
gingercat Posted June 17, 2005 Author Posted June 17, 2005 I assume by the deafening silence that nobody has seen this problem before. Not to worry, got myself 2 new PICs (1 for spare) and the core module is once again working correctly.
