Ld pin for DIN doesn't trigger
gingercat
Hi All,
I've just been trying to put the finishing touches to my MIDI organ console, but in the process of doing so, I think I shorted something (PIC got very hot...) and since then my DIN modules won't work.  After a lot of swearing and pulling of hair I think I've tracked down the problem:
-DIN modules work correctly, I've tested them with my other core module
-I can manually short the input terminals to the core module and it picks up the fake "inputs"
-Clock out (RD3 on PIC) is running nicely
-Ld pin (RD2 on PIC) isn't pulsing (I've tested this on a scope at work)
So my question is (finally), have I fried my PIC beyond all repair or might a complete re-flash work?  I can reprogram the core via MIDI so most of it is working (including the LCD).
I think I saw a message on the LCD when I installed MIOS 1.8 (to try and fix the problem) which said "fixing...." but I didn't spot what it thought it was fixing.
Thanks for any help you can give,
Chris.
