Ok.When i power up the core and sid module (without LCD) i get a message in MIDI-Ox at Input window SYSX: F0 00 00 7E 40 00 01 F7 and the same in output window  SYSX: F0 00 00 7E 40 00 01 F7 .
When i want to send MIOS to the PIC via MIDI all the time  I get this messages .I can't upload mios system??? Whats wrong???
the bootstrap should send out a message when the core starts, so that seems to be working.
it will keep sending until it has completed the mios upload.
i do not use midiox, so i'm not sure why you see it also in the midi out.
that should not be happening.
maybe you should turn midi thru off. or there is something wrong with your midi connections.
if you are sure that everything is ok, then you should try serge's syses loader, from OnAcid's post.
it is simpler to use.
