fanir Posted October 17, 2005 Posted October 17, 2005 Any ideas?I've seen a couple handmade/manual. http://chaokhun.kmitl.ac.th/~kswichit/easy1pcb/Jumpline.jpgHow would I do that?
ImAlive Posted October 17, 2005 Posted October 17, 2005 This sure is easy, but you won't be able to do a CORE module layout with this ;DYou just "draw" your traces directly onto the copper-plated PCB with a resistant marker-pen. Then you throw the PCB into your etching solution (like FeCl3), wait, take it out, clean it, remove the ink with alcohol, and ta-daa ;)I did my modules with the "Iron-on" method, as mentioned in the wiki.
jman Posted October 25, 2005 Posted October 25, 2005 In the old days we used the nail polish to draw the lines. They were not smooth, but the laquer was holding strong. :-)
