My MIDIbox SID project (help needed: clocking the SID synchronous to the PIC)
Nestle
Keep an eye out on eBay for crappy old keyboards that you can rip to bits... I see a good cheap casio POS for less than $30 about 5 times a week. I scored a nice 49 key MIDIMan controller for $7 :)
True true!
Maybe I can make a built-in keyboard after all then!! In my case there is around 45 cm space for keyboard. I would be ace if I wouldnt need a separate controller.
Is it difficult to save working midi out and keys from synth?
At the moment I try to figure if it is possible to add midi-out jack into M-Audio eKeys that is just perfect for my needs, minus midi, of course  :-\
Nestle
Nah it's a piece of cake, you're just re-casing it really, no electronic alterations necessary...
The signal is probably generated straight from the input pins of the chip to USB, so it's unlikely that there's a non-USB midi signal anywhere near it... You're probably after a USB-MIDI Interface, not sure if the MBHP USB module would be suitable?
I think it is easier to find some small used midi synth and make most of it. It is just so frustrating to know that there is a perfect keyboard for 49 euros, but only without midi. Is it possible to make midi keyboard ot of synth that does not have midi out? I mean, isn't most of the synths still controlled internally via midi?
Gotta keep searching or pick another case that can hold a bit longer keyboard.
I found Casio CZ-1000 for 10 euros to fill my keyboard controller problem.  8)
I have decised to change my casing plans, and will use my old SX-64 as a case for my midibox.
Now I am ready for control surface, it will be a busy week!
Roope
Ps. Still, about clocking the SID synchronous to the PIC, is it for real or have this bug softfixed in latest software? Plz plz plz  :P
It's for real. You'll have to use clock from the PIC to ensure SID register updates to be syncronized.
Moebius
Moebius
Thanks, I will do that. Just needed confirmation.
I got this today:
I think it will make a good companion for MidiBOX SID ;)
Nestle
