goule Posted January 13, 2006 Report Posted January 13, 2006 hello,I'm a C programmer I'd like to translate this function into assembler code (because it needs to be optimized) :// Integer division (a div b)unsigned int ADK_DIV(unsigned int a, unsigned int b){ unsigned int reste = 0; unsigned char count = 16; char c; do { c = ((a >> (8*sizeof(a)-1)) & 1); a <<= 1; reste <<= 1; if © reste |= 1; if (reste >= b) { reste -= b; a |= 1; } } while (--count); return a;}Thanks for anybody who could help me !Goule
TK. Posted January 14, 2006 Report Posted January 14, 2006 Hi Goule,in the clockbox application you will find an assembly based division routine in "mclock.c" (search for __asm)However, here another hint: if your program just only converts value A to B based on static parameters, then you could also use a table (constant array) with the required number of entries. This is significantly faster, and for common CC's it doesn't consume that much memory (e.g. a table of 128 entries allocate the same memory like 64 instructions)I'm normaly using perl scripts to calculate such tables, example:#!/usr/bin/perlprint "const unsigned char exp_table[128] = {\n ";int i;for($i=0; $i<128; ++$i){ my $value = int(0x80 * (1-exp(-$i/32))); printf "0x%02x, ", $value; if( !(($i+1) % 8) ) { # linebreak printf "\n "; }}print "};\n";[/code] generates: [code]const unsigned char exp_table[128] = { 0x00, 0x03, 0x07, 0x0b, 0x0f, 0x12, 0x15, 0x19, 0x1c, 0x1f, 0x22, 0x25, 0x28, 0x2a, 0x2d, 0x2f, 0x32, 0x34, 0x37, 0x39, 0x3b, 0x3d, 0x3f, 0x41, 0x43, 0x45, 0x47, 0x48, 0x4a, 0x4c, 0x4d, 0x4f, 0x50, 0x52, 0x53, 0x55, 0x56, 0x57, 0x58, 0x5a, 0x5b, 0x5c, 0x5d, 0x5e, 0x5f, 0x60, 0x61, 0x62, 0x63, 0x64, 0x65, 0x65, 0x66, 0x67, 0x68, 0x69, 0x69, 0x6a, 0x6b, 0x6b, 0x6c, 0x6c, 0x6d, 0x6e, 0x6e, 0x6f, 0x6f, 0x70, 0x70, 0x71, 0x71, 0x72, 0x72, 0x72, 0x73, 0x73, 0x74, 0x74, 0x74, 0x75, 0x75, 0x75, 0x76, 0x76, 0x76, 0x77, 0x77, 0x77, 0x77, 0x78, 0x78, 0x78, 0x78, 0x79, 0x79, 0x79, 0x79, 0x79, 0x7a, 0x7a, 0x7a, 0x7a, 0x7a, 0x7a, 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d, };Best Regards, Thorsten.
