kokoon Posted February 10, 2006 Report Posted February 10, 2006 not a "track" but still:the bassline is a 8580 and the higher pitched sequence that comes in later is a 6581. the filters are SIDs' own. the drums are Roland R-8.then there's also a yamaha 1005 analogue delay, an old parametric eq and a cheap zoom reverb.and yes, i know there's too much delay and reverb :) i "mastered" it on headphones.http://s5.yousendit.com/d.aspx?id=2JGI7K0LEO4QM38XU1OLGSI4BR Quote
thefRont Posted February 10, 2006 Report Posted February 10, 2006 groovy in the beginning but a bit too monotone in the later part. sounds like it's not really finished yet ;)bring in some more SID-like samples and it will rock ;) Quote
kokoon Posted February 11, 2006 Author Report Posted February 11, 2006 i'm not even going to make a track out of it... i put it here just to display the sounds SIDs can make. that's why no other sounds. and i didn't want to multitrack it and record more of the same SIDs later because what you hear is really recorded in one take.anyway, thanks for the comment :) Quote
TK. Posted February 11, 2006 Report Posted February 11, 2006 I like the constant time slides :)The drums are groovy, but mixing needs improvements. However, for a live session it sounds like you had a lot of fun! :)Best Regards, Thorsten. Quote
kokoon Posted February 11, 2006 Author Report Posted February 11, 2006 err TK how do i put this... actually i haven't upgraded the SID app yet... ;) so - the slides aren't constant time... but you'd probably hardly notice the difference - each sid line has only 1 different slide. ;Di don't have a bankstick yet and i don't want to loose some patches yet - i'll upgrade when i finish a track i'm working on. Quote
