eagle pcbs real size!?
Guest mferolla
Guest mferolla
Hy everybody,
i wantes to know if anybody experience that when you are exporting the image file from eagle to make the pcb,  yo dont get the correct size  >:( , I have tried a lot of ways and I can't have the reall size to make it!?!?!  If anybody knows how to fix it, its going to be grate!!!!
thanxs  :P
As far as I know, the issue has to do with the resolution being 300pdi, but someone else should elaborate on this.
The way I checked to see if the printouts of the circuits were correct was to lay the PIC18F452 over the printout, and see if the pins lined up with the holes for the pads.  Does that help?
