Well..
Many people have found this secret "hidden" function, by using compiled Midibox64 application and failing to reading the documentation :D
I don't know the software solution (see the examples), but if you leave analog input pin floating and read the value and scale it down to 1-10, would that be random enough?  ;D
Moebius
There's already a RNG in MBSEQ :)
;;  This function generates a new random number
;;  OUT: new random number in SEQ_RANDOM_SEED_[LH]
SEQ_CORE_GenRandomNumber
SET_BSR SEQ_BASE
movf SEQ_RANDOM_SEED_L, W, BANKED
mulwf SEQ_RANDOM_SEED_H, BANKED
movf TMR0L, W
addwf PRODL, W
movwf SEQ_RANDOM_SEED_L, BANKED
movlw 0x69
addwfc PRODH, W
movwf SEQ_RANDOM_SEED_H, BANKED
return
Scope the Humanizer functions out for a scaling example:
;;  this function applies a random value to a byte
;;  IN: pointer to byte in FSR1
;;      intensity in TMP1
;;  OUT: modified byte
SEQ_HUMANIZE_Modify
call SEQ_CORE_GenRandomNumber ; generate new random number
;; scale depending on intensity
rlf TMP2, W
rlf WREG, W
rlf WREG, W
andlw 0x78
mulwf SEQ_RANDOM_SEED_L, BANKED ; scaled result in PRODH
;; add/subtract depending on SEQ_RANDOM_SEED_H[0]
BIFCLR SEQ_RANDOM_SEED_H, 0, BANKED, rgoto SEQ_HUMANIZE_Modify_Add
SEQ_HUMANIZE_Modify_Sub
movf PRODH, W
subwf INDF1, W
;; saturate on overflow
IFSET WREG, 7, movlw 0x00
movwf INDF1
;; value should never be 0x00
movf INDF1, W
skpnz
incf INDF1, F
return
movf PRODH, W
addwf INDF1, W
IFSET WREG, 7, movlw 0x7f
movwf INDF1
return
:) TK beat us to it again!
Okay,
thanks for that piece of code - I wouldn't have found it, as I have no MBSEQ  :P
Now, I don't know much about Assembler, what does the code do? What is the range of the values that are created? How can I use it in my C code?
In my app generating the random values is not a real-time issue, so is there any other piece of [tt]C[/tt] code that might be easier to understand for me and which does the same?
Sorry for my ignorance, I'm still learning...  ::)
Thanks a lot, ilmenator
The "sid_random" application gets use of an external "real random" generator
In C, the "software random generator" in SEQ_CORE_GenRandomNumber function would look similar to this:
[code]
unsigned char random_seed_l;
unsigned char random_seed_h;
void gen_random_number(void)
  unsigned int tmp = random_seed_l * random_seed_h;
  random_seed_l = TMR0L + (unsigned char)(tmp & 0xff);
  random_seed_h = 0x69 + (unsigned char)(tmp >> 8);
[/code] Maybe with some additional XOR operations the random value distribution could be improved, but I'm not an expert on this topic... Best Regards, Thorsten. [/code]
