ReinerS Posted April 29, 2006 Posted April 29, 2006 Hi,I want to use the LCD display to show disply status messages from the Hauptwerk organ program. Looking at the MIOS-sysex implementation I found that MIOS should be able to show information on the LCD when the correct sysex-messages are sent. This sounded good, so I went ahead and got an LCD for my Midio128, which I use to set stops from my console.I am very happy to report that the display works, thanks to you all for the good instructions! My problem:Apparently Midio128 also makes use of the display (showing each button press and incoming message). And the display does not show anything when I send the sysex message to the core, so I guess the MIOS display function is disbaled by the midio128 application.Is this so? So I will have to adapt the midio128 application?best wishesReiner
ReinerS Posted April 30, 2006 Author Posted April 30, 2006 Just downloaded the MPLab and disabled the Midio128 LCD handling, so now messages I send via the MIOS sysex messages appear and remain.So this one is solved for me.GreetingsReiner
