Thomas Posted May 31, 2006 Posted May 31, 2006 Hallo!Board debugging no. 2354...I have 5 DIN - shift registers. That means 40 Button and 40 LEDs. (All 40 LEDs work.)BUT: on the 3th shift register only Button 0-5 work and on the 4th only button 7 (pin 1F(Hex) 31(dec)) on the 5th DIN-shift register only Button 7 (pin 27(hex) 39(dec). Electrical connetions seem to be ok. No short cuts or broken connection. Any Ideas how this can happen? Is shift register 3 damaged? Other possibilities before heating the soldering iron and destroy a 74HC165?
audiocommander Posted May 31, 2006 Posted May 31, 2006 Have you tried switching the ICs (eg. 2nd with 3rd), so you'd see if you got two damaged ICs. If it's the same result, maybe it's a coding error?
Thomas Posted June 1, 2006 Author Posted June 1, 2006 I cannot switch the ICs...the only thing I can do is to remove them destructively. (SO-package directly soldered) That's why I ask before I destroy them.
audiocommander Posted June 2, 2006 Posted June 2, 2006 that could possibly be the reason: maybe they got destroyed by soldering too hot & too long :-\ It is said, that some ICs are very sensitive...I think if there's no real good reason (eg AIN "purists"), sparing the 5ct for IC-sockets is actually no good idea...have you tried testing with MIOSStudio? You can directly invoke DIN_PinGet() from the debug-interface (maybe you have to stop the User-Timer first). I have been very lucky for this handy interface when debugging my last DOUT struggles...And if you're working with your own application: have you tried uploading a DIN-example app to see if that one is working? I had some strange errors in the past that were directly connected to some garbage in my code I have simply overseen. I'd check that before desoldering the ICs.;)Michael
Thomas Posted June 2, 2006 Author Posted June 2, 2006 Thank. Good ideas. I didn't think on the debug interface...Btw. the oter problem with damaged code seems to be solved. Don't know why and how. I only startet with a simplier application by commend some parts out and step by step decommand them. And I use a new power connection where I could messure U and I. Btw. flashing uses a little more current, but only some mA.
