Hi docbrown,
Data_out (Acknowledge) is pin 10. Data_in is pin 2. Vdd_enable is pin 4. Vpp_enable is pin 5, and clock is pin 3. Signal ground are from pins 18 to 25. Attached is a pinout of the D25. Hope this will help.
Regards
Shum
130_D25pinout_jpg6d7190bbe5e90fe5d76ede9
Hi docbrown,
Regards
Shum
Shum,
I will re-wire this burner again. No wonder the red light is always on  >:(  Looking at the connector in the diagram, it seems like its facing back which is the conductor side, but not the pin side.
thanks... ;D ;D
Shum,
Just to give you an update. After I switch around the connection, it finnaly works!!
Yay!! I loaded the bootstrap on the PIC... ;D ;D ;D ;D
thanks again..
Hi docbrown,
Glad to be of service. Your are welcome.
Good luck with your midibox project.
Shum
