Hola, ...sorry, can't speak español, but there are indeed some of us using Macs. I don't know what you want to do with it, if you want to code your own applications, see here: http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac
For a normal Midibox (eg MB64E) the OS makes no difference, as everything is done by MIDI (you need a MIDI-extension box or card, of course).
You just need a pre-burned pic that contains the first level bootloader, because afaik there is no bootloader burn-software available for the mac. But SmashTV or Mike also sell preburned PICs!
(hope this helps ;)
Cheers,
Michael
  • 1 month later...
creo que no existe diferencia entre mac y pc porque todo se controla via MIDI y pues el midi no tiene que ver con mac o pc.
