Vektor Posted July 21, 2006 Posted July 21, 2006 What about a module that has a texas instruments or analogue devices dsp processor on it?It could be user configured with a set of effects and the parameters controlled by the core module...I think this would be possible and I'd really like to help working on developing one.Unfortunatly I only have knowledge of dsp and none about assembler.Any Ideas?
Digineural Posted July 21, 2006 Posted July 21, 2006 This might be a good place to start. At least you could get to learn the coding side without touching too much hardwarehttp://www.booyaka.com/~oncken/http://www.harmony-central.com/Computer/Programming/Unfortunatly I only have knowledge of dsp and none about assembler.Thats a little clue ;) You might want to start with assembler first or at least C/C++. Part of the problem with marrying DSP to the MB projects is complexity. I think once you get a good idea of how the ICs work and how to interface them programmatically with the MIOS, you may be able to then create a DSP module for the MB project. You may also notice audio quality changes when going to DSP. Although DSP quality is getting better, there is nothing like pure analog tone. I greatly support this idea. :D I think this expansion is in line with TKs vision (correct me if I'm wrong) and I'm all for it ... I'll try to look more into it and see how I can help.My wife is going to kill me ...
Digineural Posted July 21, 2006 Posted July 21, 2006 I thought I saw this in the forums before ...http://www.midibox.org/forum/index.php?topic=3495.0
seppoman Posted July 21, 2006 Posted July 21, 2006 A more recent thread about Mrs Parker:http://www.midibox.org/forum/index.php?topic=7159.0Seppoman
