bluem Posted August 10, 2006 Posted August 10, 2006 hi all.. i'am new here, maybe here was this question....i was make panel for sid from mbsid_panel2fix.dwg and i would like to ask you - which type of lcd display i can use...(dimension etc, because in http://www.reichelt.de/ i dont find it...)thanks:)
stryd_one Posted August 10, 2006 Posted August 10, 2006 Hi bluem welcome to the forum.If you check the pages at www.ucapps.de or use the search feature of the forum or the wiki (links above) you will find you answer :)You want a 2x20 or 2x40 CLCD with a HD44780 or compatible driver.
