carsten_the_dane Posted October 1, 2006 Report Posted October 1, 2006 HiI have made a nice picture of a button with 4 legs.What is what, and how do i connect it? Quote
audiocommander Posted October 1, 2006 Report Posted October 1, 2006 take a multimeter, set it to check diodes polarity (that means it should beep when you connect both ends) and put it to two legs. you should hear the beep if you press the button. you just need two legs.regards,Michael Quote
carsten_the_dane Posted October 1, 2006 Author Report Posted October 1, 2006 wauw, i wasnt aware of that feature. Thanks Quote
tel3 Posted October 10, 2006 Report Posted October 10, 2006 I think I have pretty much worn out the continuity setting on my multimeter doing stuff like that! :) Quote
toxictv101 Posted October 11, 2006 Report Posted October 11, 2006 find the part number on itfind the datasheet on googlebut for me it look like a switch Quote
