fdnag Posted October 1, 2006 Report Share Posted October 1, 2006 hAVING SOME DIFFICULTY!!uSING PERL MK_MIDIO128_SYX.PL MIDIO128.INI------- to make midio128.syx file!!!!The resulting file is about 1.5k in size and will not work. (it appears the file size should be about 8k)Question: will the mk_midio128_syx.pl script function properly from a windows XP command prompt?I did of course down load the active perl msi package first!!Best Regards,Tom Quote Link to comment Share on other sites More sharing options...
ReneW Posted October 2, 2006 Report Share Posted October 2, 2006 That is really funny..I am having the same problem at the moment, my MIDIO128 doesn't work either and the file size with me is also about 1.5kB. It should be about 8k? How do you know that?I'm also running XP.Curious for answers!! Quote Link to comment Share on other sites More sharing options...
OrganGrinder Posted October 2, 2006 Report Share Posted October 2, 2006 i have just successfully used midi-ox to upload the syx file without any problems.to clarify what i did...1. installed mios with mios studio2. installed midio128 with mios studio using the midio128_v2_1c package3. configured midio128.ini from the mk_midio128_syx package4. run the batch from a cmd prompt as per the mk_midi128_syx readme (needs perl)5. configured midi-ox as per the readme from mk_midi128_syx6. uploaded the midi128.syx file to midibox7. tested the configuration - and it worked without a problem.i have tried using sysexbox_18f_v1_1c, but without success, but i think that was from a totally unrelated problem with power supply (which i have rectified). i have not retried using sysexbox, so i don't know if it works as expected.OrganGrinder Quote Link to comment Share on other sites More sharing options...
