Harrgggg... How do i convert the mios.hex To mios.syx without Perl's script?
toxictv101
in fact i already try to convert the last mios puting the script hex2syx.pl
in the folder etcetc... but it doesnt work , impossible to convert
it say that the main. file need to be tcheked
is someone can send me the already converted , it would be amazing
Please help me !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if you want to convert a MIOS .hex-file, you need to give the pearl script some extra startup informations (start parameters), so it knows it can write to some special protected areas. This is a security function, because it is inteded for applications.
It's recommended to upload MIOS with MIOS Studio that can send .hex files, so you do not need to convert it.
However, if you need to convert it to .syx see the comments in the perl script.
Cheers,
Michael
ok, sorry !
i m building a midi triger interface for a 808clone.
i ve simpify the more i can the core modul , so i ve remove lcd connector and all
route that was not needed, in fact i ve just keep the midi, and the dout.
i ve upload midio128 without problem now, the problem was that the upload have to be done under 2 sec.
now it s ok ,  but like all the time , i ve got a another probleme!!!
the crystal dont seem to oscillate anymore!!!
i supose that one of the 2 pin must be HIGH (5v)  and the other Get the 10MHZ
But no one is HIGH, is it normal ???? maby is it i dont know
i tcheked all pin of the pic with oscillo, no one is moving, ((( Its not a hardware problem , because
with a another pic already programed for sid , the crystal oscillate and all pin Are dancing)))
so ..... ?????? i dont know ? if it s normal
