tokyomatik Posted November 22, 2006 Report Posted November 22, 2006 i tryed to customize a bit the main asm because i have an 2x16 displayusing mplab, but when i press f10i get this error151i remember that time ago i solved the problem moving the directory somewhere..after 10 months i forgot everything...i'm so fried...can somebody give me a tip?thanx
stryd_one Posted November 22, 2006 Report Posted November 22, 2006 hiya tokyo'I'm not sure what is happening, can you include the full error message?Thanks!
moebius Posted November 22, 2006 Report Posted November 22, 2006 i get this error151If this is THAT error, then it´s "path too long" in plain MPLAB talk ;) Move the source files closer to drive root directory, for example: C:\MB\ ...(strange that Mighty 40MB+ MPLAB still uses external 2MB- MPASM to compile sources and can´t display error messages in human readable form - Does everybody have to imitate.. uhh..)Moebius
stryd_one Posted November 22, 2006 Report Posted November 22, 2006 Introducing: Mr "I know all the MPLAB error codes by memory" Moebius!!And the crowd goes wild! ;D
moebius Posted November 22, 2006 Report Posted November 22, 2006 Well,Searching the net, I think I was wrong.. ::)Moebius
tokyomatik Posted November 22, 2006 Author Report Posted November 22, 2006 well, i don't have mplab on this computer nowbut if i'm not wrong, should be something that finish like"... the path is too complex..."in the while i tryed to move the folder of sid 1.7 303binside the directory of my disc Cand i got the error anyway(?)what's wrong?
Therezin Posted November 23, 2006 Report Posted November 23, 2006 Can MPASM handle path/filenames with spaces in them, and more than 3 letters after the ".", or is it strictly old-school?
tokyomatik Posted November 24, 2006 Author Report Posted November 24, 2006 ok, i got it the error message sayserror 151(cs file name)unresolvable label or too complexi did like this:i opened mplabi created a new projecti copied all the files inside the directory sid 1.7-303b, dragging themon the project windowi saved the project in a directory named "303" really close to the root directory(C:/303:/)i customized the asm filesand then i pressed F10should b ok but i always get that error 151!!
tokyomatik Posted November 29, 2006 Author Report Posted November 29, 2006 ....so? nobody knows a solution?i also have a new problem, suddenly my lcd doesn't show anything, but seems that the problem is about the cable or something like that, and another one is that the core doesn't want to communicate with sid, i tryed to reinstall everything from the beginning(even if i can't send the right sid application with the right setting for my 2x16 lcd!) and from mios i noticed that the core sends a midimessage that is the followingnote off c-1 velocity=00note off c-1 velocity=00note off c-1 velocity=00note off c9 velocity=120..................timing clock..................timing clocki know that i'm adisaster with this project, but : what is going on? is my sid dying?
