fowlkes Posted November 29, 2006 Posted November 29, 2006 hello -i'm suddenly stuck with a nasty little problem. things were going greatwith the pcbs i ordered from smashtv. i downloaded the midibox64 app via sysex and had navigating menus on the display with buttons, etc. i had just wired up my first bank of knobs and thought i would try uploading: http://www.ucapps.de/mios/jitter_mon_v1_3.zipto see if it would be useful for debugging them. instead, everything hangs. mios initializes the display and renders the copyright message,kicks out the sysex message and then stops. i can't seem to downloada new application to displace whatever evil has overtaken the pic. unfortunately i only have 1 midi cable right now so i don't know if there are useful messages coming back when i try to download.any tricks that might save me from having to build a pic burner? regards.
fowlkes Posted November 29, 2006 Author Posted November 29, 2006 hmmmm...this sounds promising:"The primary loader gets active immediately after power-on for about two seconds. During this time the loader waits for a SysEx command which initiates a flash write. If this command is not received, the loader deactivates itself and MIOS will be started."haha!! it worked. just powered up and hit send immediately afterwords.problem solved.
