fowlkes Posted November 29, 2006 Report Share Posted November 29, 2006 hello -i'm suddenly stuck with a nasty little problem. things were going greatwith the pcbs i ordered from smashtv. i downloaded the midibox64 app via sysex and had navigating menus on the display with buttons, etc. i had just wired up my first bank of knobs and thought i would try uploading: http://www.ucapps.de/mios/jitter_mon_v1_3.zipto see if it would be useful for debugging them. instead, everything hangs. mios initializes the display and renders the copyright message,kicks out the sysex message and then stops. i can't seem to downloada new application to displace whatever evil has overtaken the pic. unfortunately i only have 1 midi cable right now so i don't know if there are useful messages coming back when i try to download.any tricks that might save me from having to build a pic burner? regards. Quote Link to comment Share on other sites More sharing options...
fowlkes Posted November 29, 2006 Author Report Share Posted November 29, 2006 hmmmm...this sounds promising:"The primary loader gets active immediately after power-on for about two seconds. During this time the loader waits for a SysEx command which initiates a flash write. If this command is not received, the loader deactivates itself and MIOS will be started."haha!! it worked. just powered up and hit send immediately afterwords.problem solved. Quote Link to comment Share on other sites More sharing options...
