toxictv101 Posted November 30, 2006 Posted November 30, 2006 hi ,i have build some tr808 sound modul and with it a midio128 that produce 1ms trig outi also have add a din Roland sync 24 Output to be able to ctrl Roland gear with the BoX.the problem is that , it have to send 12 x 1ms pulse to get one step out of the sequencerso i would like to modifi the midio128 prog to make it send (only on 1 pin) 12 x 1ms pulse (12pulse @ 500hz) eatch time i send a note to it by midiso the roland sequ. can understand that he got to play a stepAny one Can help me , show me how to include this in the soft ?Tks
stryd_one Posted November 30, 2006 Posted November 30, 2006 There was something similar done to run gameboy sync... might be worth a search... Yeh that one :)
toxictv101 Posted November 30, 2006 Author Posted November 30, 2006 yep but its not done in the midio128 but in the sync box :s
stryd_one Posted December 1, 2006 Posted December 1, 2006 Oh so it's not the 12 pulse part that you're wondering about, but the clock itself.... Do you want it to be master only, or also slave? If you want the slave capabilities you might want to borrow code from the SEQ, otherwise just a timer should suffice... And of course you'll have to add to the CS code too. How's your ASM skills man? It won't be really simple...
toxictv101 Posted December 1, 2006 Author Posted December 1, 2006 for nowive connected the start/stop pin of the Din sync to a switch with 5 volt and the clock pin from the din sync to a dout pin, so when the corespondant note is playroland seq. think that its a clock pule, i would like to configure the midioso that it know that when these note is played, its note 1 pulse (1ms)that it have to do , but 12. or other solution would be to make the midio capable of receive the midi clockand traduce it by pulses (1 or 12 or 24 ... ) on dout.
