The CONFIG_MIDI_IN table
Jidis
Yes, it's located in mios_tables.inc, the name is "MIOS_MPROC_EVENT_TABLE", and on matches the USER_MPROC_NotifyFoundEvent function will be called.
I must clearly say, that it was a bad idea to add such a feature to MIOS, as most applications need an individual MIDI handling with different data structures. It's also not possible to realize, that a Note Off event will turn into a Note On with velocity=0 w/o duplicating table entries.
On the other hand: this is the fastest parser you will find especially for CC's
