aquira Posted March 14, 2007 Posted March 14, 2007 hi, coz im so far away from your country, i decided to burn my own PIC,and i saw in singapore they sell the 74HC14, but there are several type of them,there are with N(74HC14N)/PW/Dare they all the same?which can i use?plz reply
seppoman Posted March 14, 2007 Posted March 14, 2007 they sell the 74HC14, but there are several type of them,there are with N(74HC14N)/PW/Dare they all the same?which can i use?You can ignore the letters before the 74, they´re different from every manufacturer. The letters after the number mostly tell about the package, ROHS conform etc. D or N is often DIP. Just make sure that you get a 74HC14 and that it is in DIP package. Manufacturer and other parameters are not important.Seppoman
aquira Posted March 15, 2007 Author Posted March 15, 2007 so,that mean the letter after 74HC14 does not count?i can use any of those n/d, etcwhats a DIP?thanks
stryd_one Posted March 15, 2007 Posted March 15, 2007 You can ignore the letters before the 74whats a DIP?First google hit for "DIP package" is correct. In fact the whole first page is! I don't mean to seem rude, honestly, but it seems like you didn't even try? Everyone here is happy to help but you should show some initiative to encourage us :)
aquira Posted March 15, 2007 Author Posted March 15, 2007 sory stryd,im abit tangled, ???dont know much about IC's and termsER - IC, Logic, 7400, Special Function, SMT, MC74HC14ADwhat are those mean, can i use that ici guest im the newbiest of newbies ;D
seppoman Posted March 15, 2007 Posted March 15, 2007 A bit of reading for you:http://en.wikipedia.org/wiki/Dual_in-line_packagehttp://en.wikipedia.org/wiki/Small-Outline_Integrated_Circuithttp://en.wikipedia.org/wiki/Through-hole_technologyhttp://en.wikipedia.org/wiki/Surface-mount_technologyThe usual IC package for home use is DIP (PDIP), which is the common package type with Through-Hole-Technology. Also the boards from Smash/Mike are using them. So you want DIP!I didn´t say that the letters after the 74HC14 don´t count, just that they have different meaning regarding package type and other version info. The MC from your suggested chip means they´re from Motorola or ONSemi. Google for MC74HC14AD - first hit: http://www.chipdocs.com/datasheets/datasheet-pdf/Motorola/MC54HC14.html (Motorola)second hit: http://www.chipdocs.com/datasheets/datasheet-pdf/ON-Semiconductor/MC74HC14.html (ONSemi)There you see that the type you suggest is SOIC package and PDIP is MC74HC14AN (from both Motorola or ONSemi).Seppoman
stryd_one Posted March 15, 2007 Posted March 15, 2007 I can be a tangle sometimes :) But really you should get on google, and have a look around. Wikipedia will help a lot (edit: beaten!)
