Hi Midiboxers!!! :D
Here's my question.
Really want to know best choice between the two for mhy project: Here it is.
One core running midio128 for the midification of two manuals and other core running mb64 for the controller section; I will use the project for control the NI B4.
I think I have two way: first is to link the two in a multicore enviroment, second is to plug the two in a midimerge for having only one midi out to connect to the pc running the software.
What's the best choice, in performance, latency, ecc?
For the miboxlink, do I need to rewrite the application?
Thank you very very much!!!
Superdavies
MB-Link wins :)
MIDI Merger
    The MIDI Merger has to be enabled within the midio128.ini file (see mk_midio128_syx.zip). If activated, the MIDIO128 forwards all incoming MIDI events to the MIDI Out port. This allows you to cascade MIDI devices, i.e. to plug another MIDIO128, a MIDIbox or a keyboard behind or before the MIDIO128.
