Hi
Yesterday my Midicable got broken.....dunno why, it dosnt send or receive anything  >:( checked it with my multimeter, but only the ground pins make a beep...
469788549_7e39c97c84.jpg?v=0
so I build one myself like described here :
15-pin SUB-D          5-pin DIN
  (Pins in front-sight of the Plugs)
1                8                  2
o o o o o o o o                  o
o o o o o o o              5  o  o  4
9            15            3  o      o  1
MIDI-In Pins :       MIDI-Out Pins :
SUB-D    DIN          SUB-D    DIN
4    ->    2            8    ->    4
8    ->    4            12  ->    5
15  ->    5
Now I tested to upload some code with my self-soldered cable to my MB but it dosnt....MIOSStudio receives midisignals when I turn pots/encoders but the uploads dosnt run :(
Now my Question :
Do I need make a optocoupled Cable like in the schematic here ?
Best Regards
MTE
Stinky Horses...clean them the teeth  ;D
After 1 hour removing fuggin hotglue with my rusty knife  ;D my broken cable is now opened...
469893979_f4ebe1a202.jpg?v=0
469893975_6c6f3483b1.jpg?v=0
Now Im thinking about to buy a new one (will be expensive 20.- and more :( )
or making a little schematic, sprinting to my cellar for hunting the parts....maybe making a doku for the wiki too  :)
I'm lost in this kinda thing but the "done thing" seems to be a 7404... Maybe these will help. Maybe they will totally balls the whole thing up  ;D
Joystick Adapter NOTES:
1. A good choice for the Optoisolator 6N137. A 6N138 will work, but is slower.
2. Resistors are 5%
3. Inverter A can be an IC or a transistor.
4. It is extremely important not to ground pin 2 of the MIDI IN connector. A noise-causing ground loop will result if you do. Pin 2 of the MIDI OUT connector should be grounded. That way the shield of the MIDI cable will be grounded on one end as desired.
http://www.kpsec.freeuk.com/trancirc.htm
http://www.troikaranch.org/schematic.html
http://www.tigoe.net/pcomp/midi.shtml
http://www.tigoe.net/pcomp/labs/lab-midi-other.shtml
