goule Posted June 19, 2007 Posted June 19, 2007 Hi all,I'd like to have some realtime messages (+ why not char animations) appear briefly on the screen, so that when they dissapear, the content that was initially displayed on the screen (overwritten by the message) gets back. So I had the idea to develop some kind of "generic" function that would do MIOS_LCD_CursorSet + MIOS_LCD_PrintCString + eventually MIOS_LCD_PrintBCD3 for instance if an int is also passed as a parameter, well you got the idea ;)In the meanwhile, this function could store a copy of what's been written on the screen (typically a screen dump), so that it can easily refresh original screen when I want to get rid properly of that realtime messages. The problem is it seems impossible to do this without the use of string functions + other C functions (like itoa to display the number).Does any of you already worked on that subject ?
audiocommander Posted June 19, 2007 Posted June 19, 2007 you can simply use [tt]MIOS_LCD_MessageStart()[/tt];)Cheers,Michael
goule Posted June 19, 2007 Author Posted June 19, 2007 Hey why not :D ;D but I could never understand the meaning of that function ... ::)Tried it a few times but could never get the written msg to dissapear ... ???+ what's the use of MessageStop() ?Does that code has to be in a specific location within code lines ?Thanks anyway I'll give it a try asap ! 8)
goule Posted June 19, 2007 Author Posted June 19, 2007 Okay, I've tested the function a little deeper than the last time ;)As far as I can see, I've two remarks :- You must have the entire LCD content written previously (I mean over every single location on the LCD), otherwise the chars generated with MessageStart( ) will not dissapear ???- If you try to deal with counters & cycles to have a nice animation (lets say I want to have an animated worm running on the screen ;D (good old times)) I can't say for instance "MIOS_LCD_MessageStart(50);" for each char because it doesn't care about your counters : all the chars vanish at the same time ... (but perhaps have I done something wrong ?)What's the use of MessageStop( ) ?Thank you guys
audiocommander Posted June 19, 2007 Posted June 19, 2007 Hi Olivier,I just noticed that the description in the function overview is a bit misleading.in principle it's very (very) simple:You should call this code not from within the LCD_Tick() routine, but from somewhere else - though of course you can call it from LCD_Tick(), but the point is:MIOS_LCD_Message_Start() does nothing but preventing MIOS_LCD_Tick() from being called for the given amount of time.So the use of MessageStop() gets pretty clear; you can immediately abort the message if the delay is still active, so that Tick() is going to be called again. In both cases MIOS_LCD_Init() is called before continuing the Ticks.As I said, very simple:MIOS_LCD_MessageStartC_DECLARATION void MIOS_LCD_MessageStart(unsigned char delay)DESCRIPTION a replacement for MIOS_LCD_PrintMessage which allows to start a message without calling "MIOS_LCD_PrintString"C_IN message delay in <delay>C_OUT -C_EXAMPLE // print message on LCD for 2 seconds MIOS_LCD_CursorSet(0x00 + 0); MIOS_LCD_PrintCString("Pot value: "); MIOS_LCD_PrintHex2(MIOS_AIN_Pin7bitGet(0)); MIOS_LCD_MessageStart(255);So, it would help you in the question you asked first, cause you don't need to care about what was previously on the screen.By using the delay within a custom timer routine, I think there should also be nice (simple) animations possible. But remember that you have to use your own timer, 'cause StartMessage prevents the LCD_Tick() routine ;)Cheers,Michael
goule Posted June 20, 2007 Author Posted June 20, 2007 Thank you for that clear explanations !! ;D 8)Now it's my turn to play :DSee you guyz
