Char array = screen content
goule
Hi all,
I'd like to have some realtime messages (+ why not char animations) appear briefly on the screen, so that when they dissapear, the content that was initially displayed on the screen (overwritten by the message) gets back. So I had the idea to develop some kind of "generic" function that would do MIOS_LCD_CursorSet + MIOS_LCD_PrintCString + eventually MIOS_LCD_PrintBCD3 for instance if an int is also passed as a parameter, well you got the idea  ;)
In the meanwhile, this function could store a copy of what's been written on the screen (typically a screen dump), so that it can easily refresh original screen when I want to get rid properly of that realtime messages. The problem is it seems impossible to do this without the use of string functions + other C functions (like itoa to display the number).
Does any of you already worked on that subject ?
Hey why not  :D ;D but I could never understand the meaning of that function ...  ::)
Tried it a few times but could never get the written msg to dissapear ...  ???
+ what's the use of MessageStop() ?
Does that code has to be in a specific location within code lines ?
Thanks anyway I'll give it a try asap !
8)
Okay, I've tested the function a little deeper than the last time  ;)
As far as I can see, I've two remarks :
- You must have the entire LCD content written previously (I mean over every single location on the LCD), otherwise the chars generated with MessageStart( ) will not dissapear  ???
- If you try to deal with counters & cycles to have a nice animation (lets say I want to have an animated worm running on the screen  ;D (good old times)) I can't say for instance "MIOS_LCD_MessageStart(50);" for each char because it doesn't care about your counters : all the chars vanish at the same time ... (but perhaps have I done something wrong ?)
What's the use of MessageStop( ) ?
Thank you guys
Hi Olivier,
I just noticed that the description in the function overview is a bit misleading.
in principle it's very (very) simple:
You should call this code not from within the LCD_Tick() routine, but from somewhere else - though of course you can call it from LCD_Tick(), but the point is:
MIOS_LCD_Message_Start() does nothing but preventing MIOS_LCD_Tick() from being called for the given amount of time.
So the use of MessageStop() gets pretty clear; you can immediately abort the message if the delay is still active, so that Tick() is going to be called again. In both cases MIOS_LCD_Init() is called before continuing the Ticks.
As I said, very simple:
C_DECLARATION void MIOS_LCD_MessageStart(unsigned char delay)
DESCRIPTION a replacement for MIOS_LCD_PrintMessage which allows to start a message without calling "MIOS_LCD_PrintString"
C_IN message delay in <delay>
C_OUT -
C_EXAMPLE
  // print message on LCD for 2 seconds
  MIOS_LCD_CursorSet(0x00 + 0);
  MIOS_LCD_PrintCString("Pot value: ");
  MIOS_LCD_PrintHex2(MIOS_AIN_Pin7bitGet(0));
  MIOS_LCD_MessageStart(255);
So, it would help you in the question you asked first, cause you don't need to care about what was previously on the screen.
By using the delay within a custom timer routine, I think there should also be nice (simple) animations possible. But remember that you have to use your own timer, 'cause StartMessage prevents the LCD_Tick() routine ;)
Cheers,
Michael
