superdavies Posted August 13, 2007 Posted August 13, 2007 HiI'm using a custom version of the app called ain64_din128_dout128_v2_0.zip written in C; I'm not very practical in the apps development but I only want to know what's the default configuration for the digital out of this app. because I Need that every single led connected to the board via the dout module will light up when the corresponding din will be pressed: is this the default config. or not? If not any suggestion to how (and where) I must modify the code?Thank you!Andrea
midiboxxer Posted August 14, 2007 Posted August 14, 2007 Hi,I´m not a programmer, but if I understand it right you have to modify the mios_tables.inc .At the moment there are no events in (MT_EOT).So have a look at this applicatin:http://www.ucapps.de/mios/ain64_din128_dout128_v1_3.zipIn the mios_tables.inc for example you can read this:;; 128 buttons and LEDs assigned to MIDI events "B0 00 <value>" to "B0 7F <value>" ;; 64 pots assigned to MIDI events "B1 00 <value>" to "B1 3F <value>"MIOS_MPROC_EVENT_TABLE ;; entry 0x00-0x0f MT_ENTRY 0xb0, 0x00 MT_ENTRY 0xb0, 0x01 MT_ENTRY 0xb0, 0x02 MT_ENTRY 0xb0, 0x03 MT_ENTRY 0xb0, 0x04 MT_ENTRY 0xb0, 0x05 MT_ENTRY 0xb0, 0x06 MT_ENTRY 0xb0, 0x07 MT_ENTRY 0xb0, 0x08 MT_ENTRY 0xb0, 0x09 MT_ENTRY 0xb0, 0x0a MT_ENTRY 0xb0, 0x0b MT_ENTRY 0xb0, 0x0c MT_ENTRY 0xb0, 0x0d MT_ENTRY 0xb0, 0x0e MT_ENTRY 0xb0, 0x0fIf I´m right, this is what you need.See also:http://www.ucapps.de/mios/mios_din_dout_pin_numbers.txtHere are the din dout nummbers, you´ll need.Hope that`s all true.GreetingsMarkus
