wicked1 Posted August 13, 2007 Posted August 13, 2007 I've got a question for TK. I was looking at your panel wiring for the din's, and how you have it right on the front panel board. I notice you have the resistors next to each encoder and button. What I'm wondering is how you got all those to the ground. Did you just run a separate ground bus as well as a 5v bus down each row of encoders/buttons? Maybe since there are a lot of LED's in that area, you needed the ground in that area anyway.I'm thinking that it is a great idea to just build it right there on the front panel proto board, because I really don't like drilling the hundreds of holes when I print PCB's.Did you find this was a good solution, or if you did it again, would you use the dout and din PCB's?thanks!
