alexglvr Posted August 17, 2007 Posted August 17, 2007 Hello,i am about to start a project. The goal is to command the registeries (i am not shure of this word..., let's say the 'sounds') of a digital pipe organ (computer software)...i will then have 1 switch (single position) and 1 led per sound. when a switch is pressed, the associated sound must be put on/off. The corresponding led must follow the state of the sound... at this state the midiio128 seems to be a good choise...a bit more complicated: i can save configurations on the organ software. i would like that, when a configuration is recalled, the leds associated to the good sounds light on...about the midi configuration :computer (which plays the sounds): channel 1keyboard 1: channel 2keyboard 2: channel 3keyboard 3: channel 4foot keyboard: channel 5but what about the midibox? the Dout for the leds must respond both to the computer and to the midi box itself... is it possible with the midiio128?a last question : is the LTC module necessary? i already have a midi chain, and i does not anderstand the aim of the rs232... thank you for your help...Sincerely,Alex
