When syncing Seq3 as slave to logic, I am getting sync drifts that could get to 16th note. The drift might start as early as during the first 16 measures.
Anyone had any similar experience?
Whomper
Yeh PC's will do that... I'm assuming you don't have this problem with other devices? Is it a drift or a wide jitter? (as in, does it correct itself and swing either side of where you want it, or does it permanently slow down more and more, getting farther and farther behind where it should be)?
Well, after some extensive debugging it seems that as I overload my computer with virtual instruments, so does it "neglect" external devices to send proper midi clock in a timely manner :-(
Whomper
