wicked1 Posted October 13, 2007 Posted October 13, 2007 Is there any problem running the aout module on +/- 15 volts? I was thinking of building it as a module in my synth cabinet and running it off the synth power supply.Thanks
seppoman Posted October 13, 2007 Posted October 13, 2007 should be no problem :) but are you planning to put a MBSEQ into your cabinet as well or did you just post in the wrong board? ;) :P
wicked1 Posted October 14, 2007 Author Posted October 14, 2007 seq. will be outside of the synth cabinet. But this way I only have to run 5 or maybe 13 wires from the sequencer to the synth. A monitor cable will work nicely. I can have the data, power, and triggers go through it.Where should I start topics about the aout?
seppoman Posted October 14, 2007 Posted October 14, 2007 As long as it's a general hardware question that is not related to one certain application, post it to the Design Concepts board - or, if you´ve already connected it and it smells strange: Testing/Troubleshooting ;)S
