jdelgoulet Posted November 29, 2007 Report Posted November 29, 2007 Hi all !I've got a problem with my Core/SID ... the audio out only delivers a big noise !I did the testtone test and it works fine : no noise, just the square wave - Voltage are ok too.Also, I have a spare core module. I did a test with it and it works fine (no noise, only good sound ;) ). This made me thinking that the problem is on the CORE module and not on the SID module.I double checked, and double checked , and double checked .... the core looks good ... I'm lost !PS : I'm running SID V1 not V2 with mios 1.9fPS 2 : I haven't done the Core.SID interconnection test ... I will do it right now but I was wondering if I should keep the SID chip stuffed ?no PS 3 : too expensive ;)Thanks for your help !!
jdelgoulet Posted November 29, 2007 Author Report Posted November 29, 2007 :P :P :P :P found it !The sil J2 were not correclty soldered ... now I everything working perfectly !
