how to create a control message
gm02froe
Hi t0gg1e4u,
The solution: every event which should be forwarded to the host software will be framed with a start and stop byte. The frame will be notified by the last core with disabled MIDI merger. Only the framed events will be forwarded by the last core (-> tunnled)' date=' all others will be filtered out.[/quote']
The framing bytes are sent when you wrap the message inside MIOS_MIDI_BeginStream() and MIOS_MIDI_EndStream()
[tt]MIOS_MIDI_BeginStream();
  MIOS_MIDI_TxBufferPut(0xb0);
  MIOS_MIDI_TxBufferPut(0x07);
  MIOS_MIDI_TxBufferPut(0x7f);
MIOS_MIDI_EndStream(); [/tt]
Best,
Michael
  • 3 weeks later...
Hi Michael
as it looks not all is that clear, since I dont have the desired results. here as I wrote in my codes:
core1:
MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_FP);
sends
MIOS_MIDI_TxBufferPut(0x91);
MIOS_MIDI_TxBufferPut(newpin);
MIOS_MIDI_TxBufferPut(pin_value ? 0x00 : 0x01);
core2:
MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_MBLINK_EP);
core2 receives this midi message, but should pass it on, since its a "framed" event, right? however, it doesnt. why not?
not sure, afaics it should work.
I expect you have wired everything correctly and core2 is able to send anything at all on the MIDI-Out?
And as you're sending a Note-On on Ch2 (!) with a Velocity of "1" (remember: "0" is muted and "127" is loudest), I expect you debug the incoming messages with a logging program and not by hearing, 'cause you most likely cannot hear the message you're sending...
If the answer to all this is "yes, of course!":
Sorry, I never worked with linked Cores so far, so I'm not an expert on debugging these issues... anyone else got an idea, maybe?
Best,
Michael
