  • entries
    8
  • comments
    3
  • views
    12,974
sharp infrared distance sensor
Today I tested a infrared distance sensor.
I am using a Sharp2d120x, with a range from 4-30cm. I soldered its ground and source to J2, as the sensor
requires 5V to operate, and its output (analog voltage proportional to the distance) to an analog input.
blogentry-10781-0-82411600-1336508148_th
The sensor works quite well, except it cannot reach the highest 5% of the midivalue, but this is not a
problem for me.
Greetings Geth
PS: The additional yellow wire and the capacitor between the (other) yellow wire and the grey one is
obsolete, I only put it there to test reducing noise. The capacitor between 5+ and ground is sufficent
to make the jittering drop under 7bit resolution, which mean no noise.
0 Comments
