GM5x5x5 in a box is done
a look inside
From the category:
Finished MIDIboxes
· 234 images
  • 234 images
  • 124 image comments
  • Taken with SAMSUNG GT-N7000
  • Focal Length 4 mm
  • Exposure Time 1/106
  • f Aperture f/2.7
  • ISO Speed 32
MaG2k
The little brownish veroboard on buttom part of the box only holds to blue LEDs. They are only to visualize that the box is "ON" because if you plug in the USB-Plug and no active sending MIDI-device is connected to the Inputs you don't see that the box is alive.
Its only a temporary solution because the two LEDs only make a blue spot in the middle of the box...i have to order some SMD-LEDs to make the hole front glowing in blue. :-)
