marcosdearaujo
Everything posted by marcosdearaujo
  1. Hello. First congratulations for the project and its facilities as well as documentation. Based on your project, I intend to build a simple version of the FLOOR BOARD to command a rack BOSS SE-70. It allows the change of 4 parameters addressable via MIDI. I wonder if there is how to optimize the use of interface DIN and DOUT because I have something in mind with 8 buttons: - 4 buttons fixed. - 2 Bank to function UP / DOW. - 2 for Bank Stick UP / DOWN. - 1 LCD Display of BIG Number would need only one mbhp_dinx1 and a mbhp_doutx1... Is that possible? How would the file pbx_config.h? I also plan to use only 1 potentiometer and for that I need to use the interface AIN or can connect directly in module processor? I remember that in applying MIDIBOX_LC, there was this possibility ... limited to 5 pots .. Is that possible? How would the file pbx_config.h? grateful. Hello, friends. First congratulations for the project and its facilities as well as documentation. Based on your project, I intend to build a simple version of the FLOOR BOARD to command a rack BOSS SE-70. It allows the change of 4 parameters addressable via MIDI. I wonder if there is how to optimize the use of interface DIN and DOUT because I have something in mind with 8 buttons: - 4 buttons fixed. - 2 Bank to function UP / DOW. - 2 for Bank Stick UP / DOWN. - 1 LCD Display of BIG Number would need only one mbhp_dinx1 and a mbhp_doutx1... Is that possible? How would the file pbx_config.h? I also plan to use only 1 potentiometer and for that I need to use the interface AIN or can connect directly in module processor? I remember that in applying MIDIBOX_LC, there was this possibility ... limited to 5 pots .. Is that possible? How would the file pbx_config.h? grateful.
