Guys,
I've just received my MBHP_CORE_LPC17 kit from SmashTv and looking forward in getting something going in the next week or two.
I was wanting to make a midi router 4 x 4 which allows merging of midi streams from the USB interface to the standard midi hardware on board and also able to filter midi data on any stream. Having MIOS32 make this relatively easy reason why I went with the uCapps way!
Since the LPC17 has Ethernet using uIP stack there doesn't seem to be much around regarding using ethernet to its best advantage. I have a keen interest to see if the was any legs on getting CopperLan protocol working on this hardward? Both midi routing and DMX over CopperLan a sinch!
Protocol IEEE 0x8927 rather than IP or UDP is 2/3 lighter.
Worth checking out the website.
www.CopperLan.org
I believe it to be better method than RTPMidi and OSC at the moment and since the source code is available, shouldn't be all that hard to implement on the ARM with the uIP stack since it uses RAW over IP and UDP?
Cheers
midiMad8051
