Lauchi
    30
Lauchi's Achievements
MIDIbox Newbie
  1. Hi, i have finished my second Core Module, but when i test the basic voltage, the Pic2 test fails. Any idea where i could have messed up? I don´t see any shortcircuits or somethinge like that :/
  2. Ok, i made Midi Test 2, and there was no Loop Back. Does that mean, that my Core is damaged? The LED from OUT Test 2 did not flicker, too :/
  3. Well i guess, than it should be the PIC, as the Module allready worked fine :/ I will take a shot look this evening, if i find any bad soldering on the crystal, but i do not think, that that is the problem...
  4. I have Mios 1.9 installed, the latest version. As i allready said, it used to work :/ Right the moment after i plugged in the Buttons, nothing worked anymore. These are my Testresults: PC1 : worked Mid1: worked Mid2: Cant remember anymore, but i think it worked Out1: Does not send upload request Out2: Did not flicker Core1-9: everything as expected (i´ve checked it, even though it allready worked once...) Core 10 & 11: No Messages ok, that is a result, but did not help me a lot... I am not much of a electronic geek :/
  5. Hi, it´s me again ;) I finished the troubleshoot guide without any results. What is more likely broken? Some Parts of the Core-Module or the PIC? Maybe i have messed up he bootloader or whatever. I am about to buy a new Pic to test it, but if the Core Module is more likely to brake, i would try to replace that first... What do you think?
  6. Nobody has an idea? :*( I don´t want to waste this money :/
  7. Hi, i have a problem with my midibox. The Controller worked and i have used it once in Traktor (only with one button to test it). When finished my solferwork by connecting all other buttons, i did not receive any midi message in midistudio. I realized, that i plugged in the DIN module reverse :/ I hope i did not burn anything... Whatever, troubleshooting did not help a Lot. The LED did not flicker when i made the midi out test, but all the 5v tests for the core tests worked out fine :/ I only left out the Midi In tests, because the troubleshooting guide did not tell me to do so. But as I said, my CoreModule allready worked and i was able to programm it :/ What else can i do? Anybody has an idea what i could have messed up? Burned the Pic? Simon
  8. I don´t have it here right now, but i am pretty sure, it has the power. I usually power up my S4 with this thing. But is there a chance, that i have to much volt? I think, i read something, and i think my PSU has 9v-12v...
  9. Update: The Din Module works. I´ve installed the ain64_din128_dout128_v2c. Now i only have to solder the ain/dout modules and then i am finished. But the LCD Doesn´t work yet :/ Would be nice if i got this to work, as I paid 10€ for it... Any Suggestions?
  10. ok, i´ve "narrowed it down". The heating up came from the fact, that my DIN module was pluged in reverse. I changed it--> the IC3 doesn´t heat up anymore. I also loaded up the MB64 hexfile, it said 179 errors that has been fixed (no issue). Whatever that means. But it was uploaded without any problems. Now, as i understood this right, the MB64 should be installed and my buttons/faders should work properly. The standardmapping but they should work. Well the one button i have solderd to the DIN Module does not send any midi. Also, if i shortcut ground and a button, shouldn´t i get a midi message? My Questions are now: How can i Test, if my LCD is burned? How can i test, if my DIN Modul is damaged? How can i test, if i have a shortcut on the core Module, or if everything is soldered properly? (Can that be an option? I thought, installing MIOS is a proove, that everything is soldered the right way?) Would be cool, if somebody helped me out, i am not much of electronic geek, and apart from the docu, i can´t do so much :/
  11. Hi, kann jemand vielleicht in der Midi-Interface Whitelist das Kontrol S4 hinzufügen? Soweit geht bei mir alles, ich kann da anscheinend aber nichts editieren. p.s. hab Win7-64bit drauf
  12. Ohh, i just realized, that i soldered a 220 res on a place, where a 1,2k should be.... That was R6.... How can i check, if i have burned everything? :/ edit: oh no, wait, i put the right resistor there, i am not used to the color codes yet... i also left out the bridges on the back, should not be a problem, as the MB64 does not use SID and stuff. edit2: "Also the polarity has not to be taken into account." from J1 means, that i do not have to measure, where my plus or minus pole on the power input is? I just thought, maybe that is the problem...
  13. And i am pretty sure, i´ve soldered something wrong. I just touched the IC3 and burned my finger really hard ;) I had this once too, but that was when i had a few shortcuts on my lcd wireing and i thought that was the reason. But it looks like it allways starts to heat up, when i plug in the power.... But why can i upload mios, if i have a shortcut or something like this? Can that be the solution for my lcd problem?
  14. ok, it did not help anything. I mirrored it and now, i´ve soldered it the right way, like my datasheet and ucapps says it. And every time i press Query my midi in messages starts freaking out and sends endless Midi Messages like this Scanning for MIDI Inputs... [1] LoopBe Internal MIDI [2] Traktor Kontrol S4 (*) MIDI Monitor ready. [3590.813] f0 00 00 7e 40 00 01 f7 [3599.316] f0 00 00 7e 40 00 01 f7 [3617.948] f0 00 00 7e 40 00 0f 00 f7 [3617.955] f0 00 00 7e 40 00 0f 00 f7 [3617.962] f0 00 00 7e 40 00 0f 00 f7 [3617.969] f0 00 00 7e 40 00 0f 00 f7 [3617.976] f0 00 00 7e 40 00 0f 00 f7 [3617.983] f0 00 00 7e 40 00 0f 00 f7 [3617.990] f0 00 00 7e 40 00 0f 00 f7 [3617.998] f0 00 00 7e 40 00 0f 00 f7 [3618.005] f0 00 00 7e 40 00 0f 00 f7 [3618.012] f0 00 00 7e 40 00 0f 00 f7 [3618.019] f0 00 00 7e 40 00 0f 00 f7 [3618.026] f0 00 00 7e 40 00 0f 00 f7 [3618.033] f0 00 00 7e 40 00 0f 00 f7 [3618.040] f0 00 00 7e 40 00 0f 00 f7 [3618.048] f0 00 00 7e 40 00 0f 00 f7 [3618.055] f0 00 00 7e 40 00 0f 00 f7 [3618.062] f0 00 00 7e 40 00 0f 00 f7 [3618.069] f0 00 00 7e 40 00 0f 00 f7 [3618.079] f0 00 00 7e 40 00 0f 00 f7 [3618.086] f0 00 00 7e 40 00 0f 00 f7 [3618.092] f0 00 00 7e 40 00 0f 00 f7 [3618.099] f0 00 00 7e 40 00 0f 00 f7 [3618.106] f0 00 00 7e 40 00 0f 00 f7 [3618.113] f0 00 00 7e 40 00 0f 00 f7 [3618.120] f0 00 00 7e 40 00 0f 00 f7 [3618.130] f0 00 00 7e 40 00 0f 00 f7 [3618.135] f0 00 00 7e 40 00 0f 00 f7 [3618.142] f0 00 00 7e 40 00 0f 00 f7 [3618.149] f0 00 00 7e 40 00 0f 00 f7 [3618.156] f0 00 00 7e 40 00 0f 00 f7 [3618.163] f0 00 00 7e 40 00 0f 00 f7 [3618.170] f0 00 00 7e 40 00 0f 00 f7 [3618.177] f0 00 00 7e 40 00 0f 00 f7 [3618.184] f0 00 00 7e 40 00 0f 00 f7 [3618.191] f0 00 00 7e 40 00 0f 00 f7 [3618.198] f0 00 00 7e 40 00 0f 00 f7 [3618.205] f0 00 00 7e 40 00 0f 00 f7 [3618.212] f0 00 00 7e 40 00 0f 00 f7 [3618.219] f0 00 00 7e 40 00 0f 00 f7 [3618.226] f0 00 00 7e 40 00 0f 00 f7 [3618.233] f0 00 00 7e 40 00 0f 00 f7 [3618.240] f0 00 00 7e 40 00 0f 00 f7 [3618.247] f0 00 00 7e 40 00 0f 00 f7 [3618.256] f0 00 00 7e 40 00 0f 00 f7 [3618.261] f0 00 00 7e 40 00 0f 00 f7 [3618.268] f0 00 00 7e 40 00 0f 00 f7 [3618.275] f0 00 00 7e 40 00 0f 00 f7 [3618.282] f0 00 00 7e 40 00 0f 00 f7 [3618.289] f0 00 00 7e 40 00 0f 00 f7 [3618.296] f0 00 00 7e 40 00 0f 00 f7 [3618.303] f0 00 00 7e 40 00 0f 00 f7 [3618.310] f0 00 00 7e 40 00 0f 00 f7 [3618.319] f0 00 00 7e 40 00 0f 00 f7 [3618.326] f0 00 00 7e 40 00 0f 00 f7 [3618.333] f0 00 00 7e 40 00 0f 00 f7 [3618.340] f0 00 00 7e 40 00 0f 00 f7 [3618.347] f0 00 00 7e 40 00 0f 00 f7 [3618.354] f0 00 00 7e 40 00 0f 00 f7 [3618.361] f0 00 00 7e 40 00 0f 00 f7 [3618.368] f0 00 00 7e 40 00 0f 00 f7 [3618.375] f0 00 00 7e 40 00 0f 00 f7 [3618.384] f0 00 00 7e 40 00 0f 00 f7 [3618.392] f0 00 00 7e 40 00 0f 00 f7 [3618.397] f0 00 00 7e 40 00 0f 00 f7 [3618.404] f0 00 00 7e 40 00 0f 00 f7 [3618.412] f0 00 00 7e 40 00 0f 00 f7 [3618.419] f0 00 00 7e 40 00 0f 00 f7 [3618.426] f0 00 00 7e 40 00 0f 00 f7 [3618.433] f0 00 00 7e 40 00 0f 00 f7 [3618.440] f0 00 00 7e 40 00 0f 00 f7 [3618.449] f0 00 00 7e 40 00 0f 00 f7 [3618.454] f0 00 00 7e 40 00 0f 00 f7 [3618.461] f0 00 00 7e 40 00 0f 00 f7 [3618.468] f0 00 00 7e 40 00 0f 00 f7 [3618.475] f0 00 00 7e 40 00 0f 00 f7 [3618.482] f0 00 00 7e 40 00 0f 00 f7 [3618.489] f0 00 00 7e 40 00 0f 00 f7 [3618.496] f0 00 00 7e 40 00 0f 00 f7 [3618.503] f0 00 00 7e 40 00 0f 00 f7 [3618.512] f0 00 00 7e 40 00 0f 00 f7 [3618.517] f0 00 00 7e 40 00 0f 00 f7 [3618.524] f0 00 00 7e 40 00 0f 00 f7 [3618.531] f0 00 00 7e 40 00 0f 00 f7 [3618.538] f0 00 00 7e 40 00 0f 00 f7 [3618.545] f0 00 00 7e 40 00 0f 00 f7 [3618.552] f0 00 00 7e 40 00 0f 00 f7 [3618.561] f0 00 00 7e 40 00 0f 00 f7 [3618.567] f0 00 00 7e 40 00 0f 00 f7 [3618.576] f0 00 00 7e 40 00 0f 00 f7 [3618.581] f0 00 00 7e 40 00 0f 00 f7 [3618.588] f0 00 00 7e 40 00 0f 00 f7 [3618.595] f0 00 00 7e 40 00 0f 00 f7 [3618.602] f0 00 00 7e 40 00 0f 00 f7 [3618.610] f0 00 00 7e 40 00 0f 00 f7 [3618.617] f0 00 00 7e 40 00 0f 00 f7 [3618.625] f0 00 00 7e 40 00 0f 00 f7 [3618.632] f0 00 00 7e 40 00 0f 00 f7 [3618.641] f0 00 00 7e 40 00 0f 00 f7 [3618.646] f0 00 00 7e 40 00 0f 00 f7 [3618.653] f0 00 00 7e 40 00 0f 00 f7 [3618.660] f0 00 00 7e 40 00 0f 00 f7 [3618.667] f0 00 00 7e 40 00 0f 00 f7 [3618.674] f0 00 00 7e 40 00 0f 00 f7 [3618.681] f0 00 00 7e 40 00 0f 00 f7 [3618.688] f0 00 00 7e 40 00 0f 00 f7 [3618.695] f0 00 00 7e 40 00 0f 00 f7 [3618.705] f0 00 00 7e 40 00 0f 00 f7 [3618.710] f0 00 00 7e 40 00 0f 00 f7 [3618.717] f0 00 00 7e 40 00 0f 00 f7 [3618.724] f0 00 00 7e 40 00 0f 00 f7 [3618.731] f0 00 00 7e 40 00 0f 00 f7 [3618.738] f0 00 00 7e 40 00 0f 00 f7 [3618.745] f0 00 00 7e 40 00 0f 00 f7 [3618.755] f0 00 00 7e 40 00 0f 00 f7 [3618.760] f0 00 00 7e 40 00 0f 00 f7 [3618.767] f0 00 00 7e 40 00 0f 00 f7 [3618.774] f0 00 00 7e 40 00 0f 00 f7 [3618.781] f0 00 00 7e 40 00 0f 00 f7 [3618.788] f0 00 00 7e 40 00 0f 00 f7 [3618.795] f0 00 00 7e 40 00 0f 00 f7 [3618.802] f0 00 00 7e 40 00 0f 00 f7 [3618.809] f0 00 00 7e 40 00 0f 00 f7 [3618.817] f0 00 00 7e 40 00 0f 00 f7 [3618.824] f0 00 00 7e 40 00 0f 00 f7 [3618.833] f0 00 00 7e 40 00 0f 00 f7 [3618.838] f0 00 00 7e 40 00 0f 00 f7 [3618.845] f0 00 00 7e 40 00 0f 00 f7 [3618.852] f0 00 00 7e 40 00 0f 00 f7 [3618.859] f0 00 00 7e 40 00 0f 00 f7 [3618.866] f0 00 00 7e 40 00 0f 00 f7 [3618.873] f0 00 00 7e 40 00 0f 00 f7 [3618.882] f0 00 00 7e 40 00 0f 00 f7 [3618.888] f0 00 00 7e 40 00 0f 00 f7 [3618.897] f0 00 00 7e 40 00 0f 00 f7 [3618.903] f0 00 00 7e 40 00 0f 00 f7 [3618.910] f0 00 00 7e 40 00 0f 00 f7 [3618.917] f0 00 00 7e 40 00 0f 00 f7 [3618.924] f0 00 00 7e 40 00 0f 00 f7 [3618.931] f0 00 00 7e 40 00 0f 00 f7 [3618.938] f0 00 00 7e 40 00 0f 00 f7 [3618.946] f0 00 00 7e 40 00 0f 00 f7 [3618.953] f0 00 00 7e 40 00 0f 00 f7 [3618.962] f0 00 00 7e 40 00 0f 00 f7 [3618.967] f0 00 00 7e 40 00 0f 00 f7 [3618.974] f0 00 00 7e 40 00 0f 00 f7 [3618.983] f0 00 00 7e 40 00 0f 00 f7 [3618.990] f0 00 00 7e 40 00 0f 00 f7 [3618.997] f0 00 00 7e 40 00 0f 00 f7 [3619.004] f0 00 00 7e 40 00 0f 00 f7 [3619.011] f0 00 00 7e 40 00 0f 00 f7 [3619.018] f0 00 00 7e 40 00 0f 00 f7 [3619.026] f0 00 00 7e 40 00 0f 00 f7 [3619.033] f0 00 00 7e 40 00 0f 00 f7 [3619.042] f0 00 00 7e 40 00 0f 00 f7 [3619.048] f0 00 00 7e 40 00 0f 00 f7 [3619.054] f0 00 00 7e 40 00 0f 00 f7 [3619.061] f0 00 00 7e 40 00 0f 00 f7 [3619.068] f0 00 00 7e 40 00 0f 00 f7 [3619.075] f0 00 00 7e 40 00 0f 00 f7 [3619.082] f0 00 00 7e 40 00 0f 00 f7 [3619.090] f0 00 00 7e 40 00 0f 00 f7 [3619.097] f0 00 00 7e 40 00 0f 00 f7 [3619.106] f0 00 00 7e 40 00 0f 00 f7 [3619.112] f0 00 00 7e 40 00 0f 00 f7 [3619.118] f0 00 00 7e 40 00 0f 00 f7 [3619.125] f0 00 00 7e 40 00 0f 00 f7 [3619.132] f0 00 00 7e 40 00 0f 00 f7 [3619.139] f0 00 00 7e 40 00 0f 00 f7 [3619.146] f0 00 00 7e 40 00 0f 00 f7 [3619.153] f0 00 00 7e 40 00 0f 00 f7 [3619.160] f0 00 00 7e 40 00 0f 00 f7 [3619.169] f0 00 00 7e 40 00 0f 00 f7 [3619.174] f0 00 00 7e 40 00 0f 00 f7 [3619.181] f0 00 00 7e 40 00 0f 00 f7 [3619.188] f0 00 00 7e 40 00 0f 00 f7 [3619.195] f0 00 00 7e 40 00 0f 00 f7 [3619.203] f0 00 00 7e 40 00 0f 00 f7 [3619.210] f0 00 00 7e 40 00 0f 00 f7 [3619.219] f0 00 00 7e 40 00 0f 00 f7 [3619.225] f0 00 00 7e 40 00 0f 00 f7 [3619.234] f0 00 00 7e 40 00 0f 00 f7 [3619.241] f0 00 00 7e 40 00 0f 00 f7 [3619.250] f0 00 00 7e 40 00 0f 00 f7 [3619.256] f0 00 00 7e 40 00 0f 00 f7 [3619.263] f0 00 00 7e 40 00 0f 00 f7 [3619.271] f0 00 00 7e 40 00 0f 00 f7 [3619.277] f0 00 00 7e 40 00 0f 00 f7 [3619.284] f0 00 00 7e 40 00 0f 00 f7 [3619.291] f0 00 00 7e 40 00 0f 00 f7 [3619.300] f0 00 00 7e 40 00 0f 00 f7 [3619.306] f0 00 00 7e 40 00 0f 00 f7 [3619.315] f0 00 00 7e 40 00 0f 00 f7 [3619.321] f0 00 00 7e 40 00 0f 00 f7 [3619.330] f0 00 00 7e 40 00 0f 00 f7 [3619.335] f0 00 00 7e 40 00 0f 00 f7 [3619.342] f0 00 00 7e 40 00 0f 00 f7 [3619.349] f0 00 00 7e 40 00 0f 00 f7 [3619.356] f0 00 00 7e 40 00 0f 00 f7 [3619.363] f0 00 00 7e 40 00 0f 00 f7 [3619.370] f0 00 00 7e 40 00 0f 00 f7 [3619.379] f0 00 00 7e 40 00 0f 00 f7 [3619.384] f0 00 00 7e 40 00 0f 00 f7 [3619.391] f0 00 00 7e 40 00 0f 00 f7 [3619.398] f0 00 00 7e 40 00 0f 00 f7 [3619.405] f0 00 00 7e 40 00 0f 00 f7 [3619.412] f0 00 00 7e 40 00 0f 00 f7 [3619.419] f0 00 00 7e 40 00 0f 00 f7 [3619.427] f0 00 00 7e 40 00 0f 00 f7 [3619.434] f0 00 00 7e 40 00 0f 00 f7 [3619.441] f0 00 00 7e 40 00 0f 00 f7 [3619.448] f0 00 00 7e 40 00 0f 00 f7 [3619.455] f0 00 00 7e 40 00 0f 00 f7 [3619.462] f0 00 00 7e 40 00 0f 00 f7 [3619.469] f0 00 00 7e 40 00 0f 00 f7 [3619.476] f0 00 00 7e 40 00 0f 00 f7 [3619.483] f0 00 00 7e 40 00 0f 00 f7 [3619.491] f0 00 00 7e 40 00 0f 00 f7 [3619.498] f0 00 00 7e 40 00 0f 00 f7 [3619.507] f0 00 00 7e 40 00 0f 00 f7 [3619.514] f0 00 00 7e 40 00 0f 00 f7 [3619.520] f0 00 00 7e 40 00 0f 00 f7 [3619.527] f0 00 00 7e 40 00 0f 00 f7 [3619.534] f0 00 00 7e 40 00 0f 00 f7 [3619.541] f0 00 00 7e 40 00 0f 00 f7 [3619.548] f0 00 00 7e 40 00 0f 00 f7 [3619.556] f0 00 00 7e 40 00 0f 00 f7 [3619.563] f0 00 00 7e 40 00 0f 00 f7 [3619.572] f0 00 00 7e 40 00 0f 00 f7 [3619.577] f0 00 00 7e 40 00 0f 00 f7 [3619.584] f0 00 00 7e 40 00 0f 00 f7 [3619.591] f0 00 00 7e 40 00 0f 00 f7 [3619.599] f0 00 00 7e 40 00 0f 00 f7 [3619.605] f0 00 00 7e 40 00 0f 00 f7 [3619.612] f0 00 00 7e 40 00 0f 00 f7 [3619.620] f0 00 00 7e 40 00 0f 00 f7 [3619.627] f0 00 00 7e 40 00 0f 00 f7 [3619.636] f0 00 00 7e 40 00 0f 00 f7 [3619.641] f0 00 00 7e 40 00 0f 00 f7 [3619.648] f0 00 00 7e 40 00 0f 00 f7 [3619.655] f0 00 00 7e 40 00 0f 00 f7 [3619.662] f0 00 00 7e 40 00 0f 00 f7 [3619.669] f0 00 00 7e 40 00 0f 00 f7 [3619.676] f0 00 00 7e 40 00 0f 00 f7 [3619.684] f0 00 00 7e 40 00 0f 00 f7 [3619.691] f0 00 00 7e 40 00 0f 00 f7 [3619.700] f0 00 00 7e 40 00 0f 00 f7 [3619.707] f0 00 00 7e 40 00 0f 00 f7 [3619.715] f0 00 00 7e 40 00 0f 00 f7 [3619.722] f0 00 00 7e 40 00 0f 00 f7 [3619.730] f0 00 00 7e 40 00 0f 00 f7 [3619.737] f0 00 00 7e 40 00 0f 00 f7 [3619.744] f0 00 00 7e 40 00 0f 00 f7 [3619.751] f0 00 00 7e 40 00 0f 00 f7 [3619.758] f0 00 00 7e 40 00 0f 00 f7 [3619.765] f0 00 00 7e 40 00 0f 00 f7 [3619.772] f0 00 00 7e 40 00 0f 00 f7 [3619.780] f0 00 00 7e 40 00 0f 00 f7 [3619.786] f0 00 00 7e 40 00 0f 00 f7 [3619.795] f0 00 00 7e 40 00 0f 00 f7 [3619.800] f0 00 00 7e 40 00 0f 00 f7 [3619.807] f0 00 00 7e 40 00 0f 00 f7 [3619.814] f0 00 00 7e 40 00 0f 00 f7 [3619.821] f0 00 00 7e 40 00 0f 00 f7 [3619.829] f0 00 00 7e 40 00 0f 00 f7 [3619.836] f0 00 00 7e 40 00 0f 00 f7 [3619.844] f0 00 00 7e 40 00 0f 00 f7 [3619.850] f0 00 00 7e 40 00 0f 00 f7 [3619.859] f0 00 00 7e 40 00 0f 00 f7 [3619.864] f0 00 00 7e 40 00 0f 00 f7 [3619.871] f0 00 00 7e 40 00 0f 00 f7 [3619.878] f0 00 00 7e 40 00 0f 00 f7 [3619.885] f0 00 00 7e 40 00 0f 00 f7 [3619.893] f0 00 00 7e 40 00 0f 00 f7 [3619.900] f0 00 00 7e 40 00 0f 00 f7 [3619.908] f0 00 00 7e 40 00 0f 00 f7 [3619.915] f0 00 00 7e 40 00 0f 00 f7 [3619.924] f0 00 00 7e 40 00 0f 00 f7 [3619.930] f0 00 00 7e 40 00 0f 00 f7 [3619.937] f0 00 00 7e 40 00 0f 00 f7 [3619.944] f0 00 00 7e 40 00 0f 00 f7 [3619.951] f0 00 00 7e 40 00 0f 00 f7 [3619.958] f0 00 00 7e 40 00 0f 00 f7 [3619.965] f0 00 00 7e 40 00 0f 00 f7 [3619.973] f0 00 00 7e 40 00 0f 00 f7 [3619.979] f0 00 00 7e 40 00 0f 00 f7 [3619.988] f0 00 00 7e 40 00 0f 00 f7 [3619.993] f0 00 00 7e 40 00 0f 00 f7 [3620.000] f0 00 00 7e 40 00 0f 00 f7 [3620.007] f0 00 00 7e 40 00 0f 00 f7 [3620.014] f0 00 00 7e 40 00 0f 00 f7 [3620.021] f0 00 00 7e 40 00 0f 00 f7 [3620.028] f0 00 00 7e 40 00 0f 00 f7 [3620.037] f0 00 00 7e 40 00 0f 00 f7 [3620.043] f0 00 00 7e 40 00 0f 00 f7 [3620.052] f0 00 00 7e 40 00 0f 00 f7 [3620.058] f0 00 00 7e 40 00 0f 00 f7 [3620.065] f0 00 00 7e 40 00 0f 00 f7 [3620.072] f0 00 00 7e 40 00 0f 00 f7 [3620.079] f0 00 00 7e 40 00 0f 00 f7 [3620.086] f0 00 00 7e 40 00 0f 00 f7 [3620.093] f0 00 00 7e 40 00 0f 00 f7 [3620.100] f0 00 00 7e 40 00 0f 00 f7 [3620.107] f0 00 00 7e 40 00 0f 00 f7 [3620.114] f0 00 00 7e 40 00 0f 00 f7 [3620.121] f0 00 00 7e 40 00 0f 00 f7 [3620.128] f0 00 00 7e 40 00 0f 00 f7 [3620.135] f0 00 00 7e 40 00 0f 00 f7 [3620.142] f0 00 00 7e 40 00 0f 00 f7 [3620.149] f0 00 00 7e 40 00 0f 00 f7 [3620.156] f0 00 00 7e 40 00 0f 00 f7 [3620.164] f0 00 00 7e 40 00 0f 00 f7 [3620.171] f0 00 00 7e 40 00 0f 00 f7 [3620.180] f0 00 00 7e 40 00 0f 00 f7 [3620.186] f0 00 00 7e 40 00 0f 00 f7 [3620.193] f0 00 00 7e 40 00 0f 00 f7 [3620.200] f0 00 00 7e 40 00 0f 00 f7 [3620.207] f0 00 00 7e 40 00 0f 00 f7 [3620.214] f0 00 00 7e 40 00 0f 00 f7 [3620.221] f0 00 00 7e 40 00 0f 00 f7 [3620.229] f0 00 00 7e 40 00 0f 00 f7 [3620.236] f0 00 00 7e 40 00 0f 00 f7 [3620.244] f0 00 00 7e 40 00 0f 00 f7 [3620.250] f0 00 00 7e 40 00 0f 00 f7 [3620.257] f0 00 00 7e 40 00 0f 00 f7 [3620.264] f0 00 00 7e 40 00 0f 00 f7 [3620.271] f0 00 00 7e 40 00 0f 00 f7 [3620.278] f0 00 00 7e 40 00 0f 00 f7 [3620.285] f0 00 00 7e 40 00 0f 00 f7 [3620.293] f0 00 00 7e 40 00 0f 00 f7 [3620.300] f0 00 00 7e 40 00 0f 00 f7 [3620.309] f0 00 00 7e 40 00 0f 00 f7 [3620.314] f0 00 00 7e 40 00 0f 00 f7 [3620.321] f0 00 00 7e 40 00 0f 00 f7 [3620.328] f0 00 00 7e 40 00 0f 00 f7 [3620.335] f0 00 00 7e 40 00 0f 00 f7 [3620.342] f0 00 00 7e 40 00 0f 00 f7 [3620.349] f0 00 00 7e 40 00 0f 00 f7 [3620.357] f0 00 00 7e 40 00 0f 00 f7 [3620.364] f0 00 00 7e 40 00 0f 00 f7 [3620.373] f0 00 00 7e 40 00 0f 00 f7 [3620.378] f0 00 00 7e 40 00 0f 00 f7 [3620.385] f0 00 00 7e 40 00 0f 00 f7 [3620.392] f0 00 00 7e 40 00 0f 00 f7 [3620.399] f0 00 00 7e 40 00 0f 00 f7 [3620.406] f0 00 00 7e 40 00 0f 00 f7 [3620.413] f0 00 00 7e 40 00 0f 00 f7 [3620.422] f0 00 00 7e 40 00 0f 00 f7 [3620.427] f0 00 00 7e 40 00 0f 00 f7 [3620.436] f0 00 00 7e 40 00 0f 00 f7 [3620.441] f0 00 00 7e 40 00 0f 00 f7 [3620.448] f0 00 00 7e 40 00 0f 00 f7 [3620.455] f0 00 00 7e 40 00 0f 00 f7 [3620.462] f0 00 00 7e 40 00 0f 00 f7 [3620.469] f0 00 00 7e 40 00 0f 00 f7 [3620.476] f0 00 00 7e 40 00 0f 00 f7 [3620.485] f0 00 00 7e 40 00 0f 00 f7 [3620.490] f0 00 00 7e 40 00 0f 00 f7 [3620.497] f0 00 00 7e 40 00 0f 00 f7 [3620.504] f0 00 00 7e 40 00 0f 00 f7 [3620.511] f0 00 00 7e 40 00 0f 00 f7 [3620.518] f0 00 00 7e 40 00 0f 00 f7 [3620.525] f0 00 00 7e 40 00 0f 00 f7 [3620.533] f0 00 00 7e 40 00 0f 00 f7 [3620.540] f0 00 00 7e 40 00 0f 00 f7 [3620.549] f0 00 00 7e 40 00 0f 00 f7 [3620.554] f0 00 00 7e 40 00 0f 00 f7 [3620.561] f0 00 00 7e 40 00 0f 00 f7 [3620.568] f0 00 00 7e 40 00 0f 00 f7 [3620.575] f0 00 00 7e 40 00 0f 00 f7 [3620.582] f0 00 00 7e 40 00 0f 00 f7 [3620.589] f0 00 00 7e 40 00 0f 00 f7 [3620.597] f0 00 00 7e 40 00 0f 00 f7 [3620.604] f0 00 00 7e 40 00 0f 00 f7 [3620.613] f0 00 00 7e 40 00 0f 00 f7 [3620.618] f0 00 00 7e 40 00 0f 00 f7 [3620.625] f0 00 00 7e 40 00 0f 00 f7 [3620.632] f0 00 00 7e 40 00 0f 00 f7 [3620.639] f0 00 00 7e 40 00 0f 00 f7 [3620.646] f0 00 00 7e 40 00 0f 00 f7 [3620.653] f0 00 00 7e 40 00 0f 00 f7 [3620.661] f0 00 00 7e 40 00 0f 00 f7 [3621.750] f0 00 00 7e 40 00 01 f7 when i pull the power plug, it stops... wtf? I don´t even have a clue what is going on ....
