Thanks nILS... I know... it was a stupid question. I knew that the current was a max value, but had a moment of late night doubt and better safe than sorry hey? I still always have to check which way round the impedance of speakers can be if they don't match (greater or smaller than the amp). Every single time!
I've built a few electronics projects before: 2 theremins; a CV to MIDI converter (which I used to have the game twister control beat-slicing, time-stretching and glitch effects in Max/MSP); a compressor; hacked my wah pedal to work better with my clavinet; amplifier; ring modulator; timer based oscillators; tape-delay; chip based 8-bit sampler (which I did design myself very slowly); USB footpedal; MIDI controller for Ableton Live and so on. However, except for the simple projects and hardware hacking, I have just built circuits from instructions, with some small adjustments. I've never had to fiddle with mains related stuff, which is why I want a pre-built AC->DC power adapter between the mains and my circuits. :)
Thanks for the heads up Gilejuk, it seems from the update at the bottom of that article there is a replacement which is reliable:
http://eshop.macsales.com/item/Other%20World%20Computing/ELITE4SAUS/
So, as I'm now slowly getting my head around it by looking through old posts here, googling and books, it looks like I am going to go with the above adapter and:
Include HF filtering capacitors (2x 2200uf electrolytic and 1x 220nf /330nf polyester)
Include 2x crowbar circuits (12v and 5v) to be extra safe
Remove the part of the circuit combining the 9VAC and 5VDC from the mbhp_8xsid_c64_psu_optimized.pdf
Can anyone please answer any of the following:
1) Am I right in concluding that I don't need a 7812 in my circuit or the 7805 in the Core circuit as the power supply (ELITE4SAUS above) will be regulated enough already?
And looking at the following circuit:
http://en.wikibooks.org/wiki/Practical_Electronics/Crowbar_circuit
2) Can anyone suggest values for SD1, Q1 and C2, or point me in the right direction for research?
3) Should I use resettable or regular fuses? Or both?
4) Is there a crowbar circuit floating around here that others have used that I can compare to this one?
Thanks again :)
