The power supply you are using will work fine since it provides the necessary 5v and 12vdc. If you are using 6582 chips you will need to install the regulator to make 9VDC out of the 12VDC from your power supply. Either way you will also need decently sized capacitors on both rails to filter out voltage spikes and glitches, without these your circuit will be unstable.
