I'm trying to control a midibox sid v2 that i built years ago with ctrlr. My machine is a literal black box, it has no controls nor display, just a power switch and input/output connections. I would really like to be able to load ctrlr as a vst inside of my daw (reaper) and control the synth as any other virtual instrument, but, so far, no luck. Here's a list of what i've tried:
	-Latest version of ctrlr, running standalone, load the panel, set midi input, control, output -> everything seems to work. Specifically, activating the midi monitor in ctrlr i can see that for any knob or parameter that i tweak in the panel, a correspondig amount of midi data is sent to the machine, and obviously changing parameters affect the sound.
	-Latest version of ctrl loaded in reaper as either vst 86, vst 64 or vst 3, either allowing ctrlr to directly control midi in/out or routing them through the host -> no luck. Checking with the midi monitor, only the buttons on the left side of the panel, (init, receive, SID1-4, link osc, link stereo, play) generate a midi output, while all the knobs and buttons of the various engines generate nothing. I can play notes just fine, but no matter what i click or turn the sound doesn't change.
	run the same thest with the Ctrlr_ac6a3185 version, got pretty much the same result. So I'm curious, has anyone managed to run the panel in ctrlr as a vst and got it to work?
