Hello!
I am not (yet) a DIY maker, but I knew this forum thanks to some comments on Mutable Instruments Forum, and I´m totally impressed by what I see here.
I am going to build a Shruthi-1 soon so I suppose that once in the DIY world, I will come here more often :)
But in this moment I just had some doubts about midi syncing and I considered interesting to ask to midi experts here.
I am setting up a setup (uhm, that was redundant) for live looping experimental improvisational performances.
My midi hardwares:
-Elektron Octatrack (needs to be set as Master in order to loop well)
-Kaoss Pad 3
-Electribe EMX1
-Waldorf Blofeld Desktop
-Shruthi-1 SMR4MK2 (coming soon)
I will also use Ableton Live Suite 8 with Max4Live, as a live looper, running in a Windows7 notebook where I am going to put a SSD disk and expand RAM at 4gb or 8 depending on the price I find (CPU is a P6200 dual core).
My audio interface is a Roland Quad Capture ("QUAD-CAPTURE incorporates a high-performance crystal master clock. By syncing the digital circuitry, driver, and DAW program to this clock, jitter and latency are reduced to a minimum").
My Midi controllers:
-Behringer FCB1010 with UnO Chip
-Behringer BCR2000
-Novation Impulse 49 (with built in arpeggiator)
-Novation Remote ZERO SL Mk2
And if all goes well I am getting a DIY Theremin by Elettrorama with Moduino-so midi out implementation.
Well, I am totally new to music, I just always wanted to make music and now I felt it was the good moment to change life.
But, for example, I did not even think that I could need to sync all this.
Now in Elektron Forum I read that there are often problems of syncing between Octatrack and Ableton.
And I started to fear, "how will I sync all this!?".
I was said "you need an innerclock System product". They look wonderful, but they are so expensive!
I would like to ask you, what would you consider the most effective and as cheap as possible syncing solution?
Cheers and super thanks!
Ser
