Vinylrider
    6
Everything posted by Vinylrider
  1. ok it is solved. My stupidity has no boundaries! For the history this was my mistake: It is the way you look the j1 if you look this way "attach file 1" its wrong but if you look that way "attach file 2" is the proper way. Thank you for the quick answers
  2. yes i know but i gave it a try and i changed the cables. i but them back now.
  3. i changed the cables but the problem stays!
  4. the micro sd it works just fine
  5. Hello, i have just assembled my first LPC core and i will use the MIDIBOX NG firmware. i have also made the sd card adaptor as in the schematics.For a memory card i use a 4 gb micro sd. When i open the core i get the message that there is NO sd card pluged. when i write on the terminal the command "sdcard" i get this : attached file at the bottom "reply.jpg" I have checked 4 times all the connections from j16 to sd card adaptor and from the j16 to the pins of the LPC. I have also checked the presence of 3,3 volt and all seem perfect! I can't find what am i do wrong. I am waitting for suggestions in order to continue my project. thanks in advance
  6. Hello i want to add something: For those user who run under windows 64bit the default installation directorie for the SDCC and the gputils is: C:\Program Files (x86)\ So you must add this line: C:\msys\1.0\bin;C:\Program Files (x86)\gputils\bin;C:\Program Files (x86)\SDCC\bin; to the path as described at the tutorial. My path for example is like this: C:\msys\1.0\bin;C:\Program Files (x86)\gputils\bin;C:\Program Files (x86)\SDCC\bin;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x86;C:\Program Files (x86)\EgisTec\MyWinLocker 3\x64;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Common Files\DivX Shared\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE\PrivateAssemblies\;C:\Program Files\MySQL\MySQL Server 5.1\bin;C:\Program Files (x86)\MATLAB\R2009b\runtime\win32;C:\Program Files (x86)\MATLAB\R2009b\bin;C:\Program Files (x86)\Java\jdk1.6.0_20\bin;C:\Program Files (x86)\Windows Live\Shared;C:\Users\vinylrider\Downloads\android-sdk-windows\tools\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;C:\MinGW\bin\; i hope i will help the others who read this.
